Every PAM module implements a specific mechanism. When you set up PAM authentication, you need to specify both the module and the module type, which defines what the module does. More than one module type, such as auth, account, session, or password, can be associated with each module.
The following table describes every PAM module, and includes the module name and the module file name. The path of each module is determined by the instruction set that is available in the Solaris release that is installed. The default path to the modules is /usr/lib/security/$ISA. The value for $ISA could be sparc or i386. See the isalist(5) man page for more information.
Table 10–1 PAM Modules|
Module Name and Module File Name |
Description |
authtok_check pam_authtok_check.so.1 |
Provides support for password management. This module performs various checks on passwords. Those check are for the length of the password, for circular shift of the login name, for password complexity, and for the amount of variation between new passwords and old passwords. See pam_authtok_check(5) for more information. |
authtok_get pam_authtok_get.so.1 |
Provides password prompting for authentication and password management. See pam_authtok_get(5) for more information. |
authtok_store pam_authtok_store.so.1 |
Provides support for authentication only. This module updates the authentication token for the user. After the successful update, the module stores the token in the specified repository or default repository. See pam_authtok_store(5) for more information. |
dhkeys pam_dhkeys.so.1 |
Provides support for Diffie-Hellman key management in authentication. This module supports Secure RPC authentication and Secure RPC authentication token management. See pam_dhkeys(5) for more information. |
dial_auth pam_dial_auth.so.1 |
Can only be used for authentication. This module uses data that is stored in the /etc/dialups and /etc/d_passwd files for authentication. This module is mainly used by the login command. See pam_dial_auth(5) for more information. |
krb5 pam_krb5_auth.so.1 |
Provides support for authentication, account management, session management, and password management. Kerberos credentials are used for authentication. See pam_krb5(5) for more information. |
ldap pam_ldap.so.1 |
Provides support for authentication and password management. Data from an LDAP server are used for authentication. See pam_ldap(5) for more information. |
projects pam_projects.so.1 |
Provides support for account management. See pam_projects(5) for more information. |
rhosts_auth pam_rhosts_auth.so.1 |
Can only be used for authentication. This module uses data that is stored in the ~/.rhosts and /etc/host.equiv files through the ruserok() routine. This module is mainly used by the rlogin and rsh commands. See pam_rhosts_auth(5) for more information. |
roles pam_roles.so.1 |
Provides support for account management only. The RBAC user_attr database determines which roles a user can assume. See pam_roles(5) for more information. |
sample pam_sample.so.1 |
Provides support for authentication, account management, session management, and password management. Used for testing. See pam_sample(5) for more information. |
smartcard pam_smartcard.so.1 |
Provides support for authentication only. See pam_smartcard(5) for more information. |
unix pam_unix.so.1 |
Provides support for authentication, account management, session management, and password management. Any of the four module type definitions can be used with this module. This module uses UNIX passwords for authentication. In the Solaris environment, the selection of appropriate name services to get password records is controlled through the /etc/nsswitch.conf file. See pam_unix(5) for more information. |
unix_account pam_unix_account.so.1 |
Provides support for account management. This module retrieves password aging information from the repository that is specified in the nsswitch.conf file. Then the module verifies that the password and the user's account have not expired. See pam_unix_account(5) for more information. |
unix_auth pam_unix_auth.so.1 |
Provides support for authentication. This module verifies the password that is contained in the PAM handle. The module checks that the user's password matches the password in the specified repository or default repository. See pam_unix_auth(5) for more information. |
unix_session pam_unix_session.so.1 |
Provides support for session management. This module initiates session management by updating the /var/adm/lastlog file. See pam_unix_session(5) for more information. |
For security reasons, these module files must be owned by root and must not be writable through group or other permissions. If the file is not owned by root, PAM does not load the module.
