To have a script for authorizations, you need to add a test that is based on the auths command (see the auths(1) man page). For example, the following line would test if the user has the authorization entered as the $1 argument:
if [ `/usr/bin/auths|/usr/xpg4/bin/grep $1` ]; then
echo Auth granted
else
echo Auth denied
fi
To be more complete, the test should include logic that checks for other authorizations that use wildcards. For example, to test if the user has the solaris.admin.usermgr.write authorization, you need to check for the strings: solaris.admin.usermgr.write, solaris.admin.usermgr.*, solaris.admin.*, and solaris.*.
If you are writing a program, use the getauthattr() function to test for the authorization.
