System Administration Guide: Security Services
Configuring RBAC (Task Map)
Task
Description
For Instructions
1. Plan for RBAC
Learn the concepts behind RBAC, examine your site's security needs, and plan how to integrate RBAC into your operation.
How to Plan Your RBAC Implementation
2. Start the User tools from the Solaris Management Console
All RBAC tasks can be performed by the User tools.
How to Run the User Tool Collection
3. Install initial users if needed
One or more existing users must be available for assignment to the first role.
How to Create Initial Users by Using the User Accounts Tool
4. Install the first role
The first role, typically Primary Administrator, needs to be installed by root user.
5. (Optional) Make root a role
To eliminate anonymous root login, root can be made a role.
How to Make Root a Role
