To create or change a rights profile, you must either assume a role that has the Primary Administrator rights profile assigned to it, or run the User Tool Collection as root user if roles have not yet been set up. To learn more about rights profiles, see RBAC Roles and Configuring Recommended Roles.
Start the Rights tool.
To run the Rights tool, you need to start the Solaris Management Console as described in How to Assume a Role in the Console Tools. Then, open the User Tool Collection, and click the Rights icon.
After the Rights tool starts, the icons for the existing rights profiles are displayed in the view pane.
Take the appropriate action for creating or changing a rights profile:
To create a new rights profile, select Add Right from the Action menu.
To change an existing rights profile, click the rights profile icon and select Properties from the Action menu (or simply double-click the rights profile icon).
Both actions display a version of the Rights Properties dialog box. The Add Right version (which follows) has a writable Name field. The standard Rights Properties dialog box has a read-only Name field because the name of a rights profile cannot be changed after it has been defined.
Type the new information. Click OK to save the rights profile.
The following table lists the tabs and fields in the Right Properties dialog box.
Tab |
Field |
Field Description |
General |
Name |
Name of the new rights profile. |
Description |
Description of the new rights profile. |
Help File Name |
Name of the HTML help file for the new rights profile. |
Commands |
Add Directory |
Opens a dialog box for adding directories that are not already in the Commands Denied or Commands Permitted columns. |
Commands Denied / Commands Permitted |
Assigns or removes a rights profile's commands. |
Opens a dialog box for assigning or removing a command's security attributes, that is, real or effective UIDs or GIDs (see Figure 6–6). Note – Assigning effective IDs is preferred over assigning real IDs. Use real IDs only when they are required by the command, such as pkgadd. |
Find (command) |
Searches the two command lists for the specified string. |
Authorizations |
Authorizations Excluded / Authorizations Included |
Assigns or removes a rights profile's authorizations. |
Supplementary Rights |
Rights Excluded / Rights Included |
Assigns or removes a rights profile's supplementary rights profiles. |
The data in the following table shows sample data for a hypothetical rights profile that is called “Restart” could be created. The example rights profile, Restart, has the commands in the subdirectory /etc/init.d assigned to it. These commands have an effective UID of 0. This rights profile would be useful for administrators who are permitted to stop and start the daemons in /etc/init.d.
Tab |
Field |
Example |
General |
Name |
Restart |
Description |
For starting and stopping daemons in /etc/init.d |
Help File Name |
Restart.html |
Commands |
Add Directory |
Click Add Directory, type /etc/init.d in the dialog box, and click OK. |
Select /etc/init.d and click Add to move the command to the Commands Permitted column. |
Set Security Attributes |
Select /etc/init.d, click Set Security Attributes, and set Effective UID = root (see Figure 6–6). |
Find (command) |
Authorizations |
Become superuser or assume a role with the PrimaryAdministration rights profile.
Use the subcommand of smprofile that is appropriate for the task.
This command requires authentication. You can apply the command to all name services. smprofile runs as a client of the Solaris Management Console server.
To add a new profile, use smprofile with the add subcommand.
To change an existing profile, use smprofile with the modify subcommand.
