SEAM Files
Table 19–1 SEAM Files
File Name
Description
~/.gkadmin
Default values for creating new principals in the SEAM Administration Tool
~/.k5login
List of principals to grant access to a Kerberos account
/etc/init.d/kdc
init script to start or stop krb5kdc
/etc/init.d/kdc.master
init script to start or stop kadmind
/etc/krb5/kadm5.acl
Kerberos access control list file; includes principal
names of KDC administrators and their Kerberos administration privileges
/etc/krb5/kadm5.keytab
Keytab file for kadmin service on master KDC
/etc/krb5/kdc.conf
KDC configuration file
/etc/krb5/kpropd.acl
Kerberos database propagation configuration file
/etc/krb5/krb5.conf
Kerberos realm configuration file
/etc/krb5/krb5.keytab
Keytab file for network application servers
/etc/krb5/warn.conf
Kerberos warning configuration file
/etc/pam.conf
PAM configuration file
/tmp/krb5cc_uid
Default credentials cache (uid is the decimal UID of the user)
/tmp/ovsec_adm.xxxxxx
Temporary credentials cache for the lifetime of the password changing operation (xxxxxx is a random string)
/var/krb5/.k5.REALM
KDC stash file; contains encrypted copy of the KDC master key
/var/krb5/kadmin.log
Log file for kadmind
/var/krb5/kdc.log
Log file for the KDC
/var/krb5/principal.db
Kerberos principal database
/var/krb5/principal.kadm5
Kerberos administrative database; contains policy information
/var/krb5/principal.kadm5.lock
Kerberos administrative database lock file
/var/krb5/principal.ok
Kerberos principal database initialization file;
created when the Kerberos database is initialized successfully
/var/krb5/slave_datatrans
Backup file of the KDC that the kprop_script script uses for propagation
PAM Configuration File
The default PAM configuration file includes entries for the authentication service, account management, session management, and password management modules.
For the authentication module, the new entries are created for rlogin, login, and dtlogin if SEAM 1.0 or 1.0.1 are installed. An example of these entries follows. All these services use the new PAM library, /usr/lib/security/pam_krb5.so.1, to provide Kerberos authentication.
These entries use the try_first_pass option, which requests authentication by using the user's initial password. Using the initial password means that the user is not prompted for another password, even if multiple mechanisms are listed.
# cat /etc/pam.conf
rlogin auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass
dtlogin auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass
other auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass
For the account management module, dtlogin has a new entry that uses the Kerberos library, as follows. An other entry is included to provide a default rule. Currently, no actions are
taken by the other entry.
dtlogin account optional /usr/lib/security/pam_krb5.so.1
other account optional /usr/lib/security/pam_krb5.so.1
The last two entries in the /etc/pam.conf file are shown next. The other entry for session management destroys user credentials. The new other entry for password management
selects the Kerberos library.
other session optional /usr/lib/security/pam_krb5.so.1
other password optional /usr/lib/security/pam_krb5.so.1 try_first_pass
