System Administration Guide: Security Services
A Typical Solaris Secure Shell Session
The Solaris Secure Shell daemon (sshd) is normally started at boot from the /etc/init.d/sshd script. The daemon listens for connections from clients. ASolaris Secure Shell session begins when the user runs the ssh, scp, or sftp command. A new sshd daemon is forked for each incoming connection. The forked daemons handle key exchange, encryption, authentication, command execution, and data exchange with the client. These session characteristics are determined by client-side configuration files and server configuration files, and potentially command-line parameters. The client and server must authenticate themselves to each other. After successful authentication, the user can execute commands remotely and copy data between hosts.
Session Characteristics
The server-side behavior of the sshd daemon is controlled by keyword settings in the /etc/ssh/sshd_config file and potentially the command-line options when sshd is started. For example, sshd_config controls which types of authentication are permitted for accessing the server.
The behavior on the client side is controlled by the Solaris Secure Shell parameters in this order of precedence:
For example, a user can override a system-wide configuration Cipher that is set to blowfish by specifying -c 3des on the command line.
Authentication
The steps in the authentication process for Solaris Secure Shell are as follows:
  1. The user runs the ssh, scp, or sftp command.
  2. The client and server agree on a shared session key.
    In v1, the remote host sends its host (RSA) key and a server (RSA) key to the client. Note that the server key is typically generated every hour and stored in memory only. The client checks that the remote host key is stored in the $HOME/.ssh/known_hosts file on the local host. The client then generates a 256 bit random number and encrypts it with the remote host's host key and server key. The encrypted random number is used as a session key to encrypt all further communications in the session.
    In v2, the remote host uses DSA in its host key and does not generate a server key. Instead, the shared session key is derived through a Diffie-Hellman agreement.
  3. The local and remote hosts authenticate each other.
    In v1, the client can use .rhosts, .rhosts with RSA, RSA challenge-response, or password-based authentication. In v2, only .rhosts, DSA, and password-based authentication are permitted.
Command Execution and Data Forwarding
After authentication is complete, the user can use Solaris Secure Shell, generally by requesting a shell or executing a command. Through the ssh options, the user can make requests, such as allocating a pseudo-tty, forwarding X11 connections or TCP/IP connections, or enabling an ssh-agent over a secure connection. The basic components of a user session are as follows:
  1. The user requests a shell or the execution of a command, which begins the session mode.
    In this mode, data is sent or received through the terminal on the client side, and the shell or command on the server side.
  2. The user program terminates.
  3. All X11 forwarding and TCP/IP forwarding is stopped. Any X11 connections and TCP/IP connections that already exist remain open.
  4. The server sends the command exit to the client, and both sides exit.
