Become superuser or assume an equivalent role.
Change directories to an audit files directory, such as /usr/audit_summary/logins.
# cd /usr/audit_summary/logins |
Read a file by using the praudit command.
# praudit 19990413000000.19990413235959.logins | more |
In this example, the audit records are converted to XML format. XML format can be displayed in a browser. The format can also be used to create a report.
# praudit -x 19990413000000.19990413235959.logins > 19990413.logins.xml |
The *xml file can be displayed in a browser. The contents of the file can be operated on by a script to extract the relevant information.
