System Administration Guide: Security Services
How to Copy an ACL
    Copy a file's ACL to another file by redirecting the getfacl output.
    % getfacl filename1 | setfacl -f -filename2
filename1
Specifies the file from which to copy the ACL.
filename2
Specifies the file on which to set the copied ACL.
Example—Copying an ACL
In the following example, the ACL on ch2.doc is copied to ch3.doc.
% getfacl ch2.doc | setfacl -f - ch3.doc
