System Administration Guide: Security Services
How to Display a User's Login Status
  1. Become superuser or assume an equivalent role.
  2. Display a user's login status by using the logins command.
    # logins -x -l username
    -x
    Displays an extended set of login status information.
    -l username
    Displays the login status for the specified user. username is a user's login name. Multiple login names must be specified in a comma-separated list.
    The logins command uses the appropriate password file to obtain a user's login status. The file can be the local /etc/passwd file , or a password database for the name service. For more information, see the logins(1M) man page.
Example—Displaying a User's Login Status
In the following example, the login status for the user rimmer is displayed.
# logins -x -l rimmer
rimmer       500     staff           10   Annalee J. Rimmer
                     /export/home/rimmer
                     /bin/sh
                     PS 010170 10 7 -1
rimmer
Identifies the user's login name.
500
Identifies the user ID (UID).
staff
Identifies the user's primary group.
10
Identifies the group ID (GID).
Annalee J. Rimmer
Identifies the comment.
/export/home/rimmer
Identifies the user's home directory.
/bin/sh
Identifies the login shell.
PS 010170 10 7 -1
Specifies the password aging information:
  • Last date that the password was changed
  • Number of days that are required between changes
  • Number of days before a change is required
  • Warning period
