You can use any of the Solaris installation methods to install Solaris Flash archives on clone systems.
The Solaris Web Start program on the Solaris 9 DVD or Solaris 9 Installation CD enables you to install Solaris Flash archives that are stored on the following:
Disc (DVD or CD)
NFS server
HTTP server
FTP server
Local tape
For installation instructions, see SPARC: Performing an Installation or Upgrade With the Solaris Web Start Program or x86: Performing an Installation or Upgrade With the Solaris Web Start Program.
The Solaris suninstall program on the Solaris 9 Software 1 of 2 CD enables you to install Solaris Flash archives that are stored on the following:
NFS server
HTTP server
FTP server
Local file
Local tape
Local device, including CD
For installation instructions, see SPARC: Performing an Installation or Upgrade With the Solaris suninstall Program or x86: Performing an Installation or Upgrade With the Solaris suninstall Program.
The custom JumpStart installation program enables you to install Solaris Flash archives that are stored on the following:
NFS server
HTTP server
FTP server
Local tape
Local device, including DVD or CD
Local file
For installation instructions, see To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation.
Solaris Live Upgrade enables you to install Solaris Flash archives that are stored on the following:
HTTP server
FTP server
NFS server
Local file
Local tape
For installation instructions, see Installing Solaris Flash Archives on a Boot Environment.
