Solaris 9 Installation Guide
Profile Keyword Descriptions and Examples
archive_location Keyword
archive_location retrieval_type location
The values of retrieval_type and location depend on where the Solaris Flash archive is stored. The following sections contain the values you can use for retrieval_type and location and examples of how to use the archive_location keyword.
NFS Server
If the archive is stored on an NFS server, use the following syntax for the archive_location keyword.
archive_location nfs server_name:/path/filename retry n
server_name
The name of the server where you stored the archive.
path
The location of the archive to be retrieved from the specified server. If the path contains $HOST, the Solaris Flash installation utilities replace $HOST with the name of the clone system that you are installing.
filename
The name of the Solaris Flash archive file.
retry n
An optional keyword. n is the maximum number of times the Solaris Flash utilities attempt to mount the archive.
Examples:
archive_location nfs golden:/archives/usrarchive
archive_location nfs://golden/archives/usrarchive
HTTP Server
If the archive is stored on an HTTP server, use the following syntax for the archive_location keyword.
archive_location http://server_name:port path/filename optional_keywords
server_name
The name of the server where you stored the archive. server_name can be a port number or the name of a TCP service that has a port number that is determined at runtime.
port
An optional port. If you do not specify a port, the Solaris Flash installation utilities use the default HTTP port number, 80.
path
filename
optional_keywords
The optional keywords that you can specify when you retrieve a Solaris Flash archive from an HTTP server.
Table 28–3 Optional Keywords to Use With archive_location http
Keywords
Value Definitions
auth basic user_name password
If the archive is located on an HTTP server that is password protected, you must include the user name and password that you need to access the HTTP server in the profile file.
Note –
The use of this authentication method in a profile that is intended for use with custom JumpStart is risky. Unauthorized users might have access to the profile file that contains the password.
timeout min
The timeout keyword enables you to specify, in minutes, the maximum length of time that is allowed to pass without receipt of data from the HTTP server before the connection is closed, reopened, and resumed from the point where the timeout occurred. If you specify a timeout value of 0 (zero), the connection is not reopened because of inactivity.
If a time-out reconnection occurs, the Solaris Flash installation utilities attempt to resume the installation at the last known position in the archive. If the Solaris Flash installation utilities cannot resume the installation at the last known position, the retrieval restarts from the beginning of the archive and the data that was retrieved prior to the timeout is discarded.
proxy host:port
The proxy keyword allows you to specify a proxy host and proxy port. You can use a proxy host to retrieve a Solaris Flash archive from the other side of a firewall. You must supply a proxy port when you specify the proxy keyword.
Example:
archive_location http://silver/archives/usrarchive.flar timeout 5
Example of the auth basic user_name password keyword:
archive_location http://silver/archives/usrarchive.flar timeout 5 user1 secret
FTP Server
If the archive is stored on an FTP server, use the following syntax for the archive_location keyword.
archive_location ftp://user_name:password@server_name:port path/filename optional_keywords
user_name:password
The user name and password that you need to access the FTP server in the profile file.
server_name
port
A is an optional port. If you do not specify a port, the Solaris Flash installation utilities use the default FTP port number, 21.
path
filename
optional_keywords
The optional keywords that you can specify when you retrieve a Solaris Flash archive from an FTP server.
Table 28–4 Optional Keywords to Use With archive_location ftp
Keywords
Value Definitions
timeout min
The timeout keyword enables you to specify, in minutes, the maximum length of time that is allowed to pass without receipt of data from the FTP server before the connection is closed, reopened, and resumed from the point where the timeout occurred. If you specify a timeout value of 0 (zero), the connection is not reopened because of inactivity.
proxy host:port
Example:
archive_location ftp://user1:secret@silver/archives/usrarchive.flar timeout 5
Local Tape
If the archive is stored on a tape, use the following syntax for the archive_location keyword.
archive_location local_tape device  position
device
The name of the tape drive where you stored the Solaris Flash archive. If the device name is a canonical path, the Solaris Flash installation utilities retrieve the archive from the path to the device node. If you supply a device name that is not a canonical path, the Solaris Flash installation utilities add /dev/rmt/ to the path.
position
Designates the place on the tape drive where you saved the archive. If you do not supply a position, the Solaris Flash installation utilities retrieve the archive from the current position on the tape drive. By specifying a position, you can place a begin script or a sysidcfg file on the tape drive before the archive.
Examples:
archive_location local_tape /dev/rmt/0n 5
archive_location local_tape 0n 5
Local Device
You can retrieve a Solaris Flash archive from a local device if you stored the Solaris Flash archive on a file system-oriented, random-access device, such as a diskette or a CD-ROM. Use the following syntax for the archive_location keyword.
Note –
You can retrieve an archive from stream-oriented devices, such as tape, by using the syntax for local tape.
archive_location local_device device path/filename file_system_type
device
The name of the drive where you stored the Solaris Flash archive. If the device name is a canonical path, the device is mounted directly. If you supply a device name that is not a canonical path, the Solaris Flash installation utilities add /dev/dsk/ to the path.
path
The path to the Solaris Flash archive, relative to the root of the file system on the device you specified. If the path contains $HOST, the Solaris Flash installation utilities replace $HOST with the name of the clone system that you are installing.
filename
file_system_type
Specifies the type of file system on the device. If you do not supply a file system type, the Solaris Flash installation utilities attempt to mount a UFS file system. If the UFS mount fails, the Solaris Flash installation utilities attempt to mount an HSFS file system.
Examples:
To retrieve an archive from a local hard drive that is formatted as a UFS file system, use the following command:
archive_location local_device c0t0d0s0 /archives/$HOST
To retrieve an archive from a local CD-ROM that has an HSFS file system, use the following command:
archive_location local_device c0t0d0s0 /archives/usrarchive
Local File
You can retrieve an archive that you stored in the miniroot from which you booted the clone system as a local file. When you perform a custom JumpStart installation, you boot the system from a CD-ROM or an NFS-based miniroot. The installation software is loaded and run from this miniroot. Therefore, a Solaris Flash archive that you stored in the CD-ROM or NFS-based miniroot is accessible as a local file. Use the following syntax for the archive_location keyword.
archive_location local_file path/filename
path
The location of the archive. The path must be accessible to the system as a local file while the system is booted from the Solaris 9 Installation CD or from the Solaris 9 DVD. The system cannot access /net when it is booted from the Solaris 9 Installation CD or from the Solaris 9 DVD.
filename
Examples:
archive_location local_file /archives/usrarchive
backup_media Profile Keyword
backup_media type path
Note –
You can use backup_media only with the upgrade option when disk space reallocation is required.
backup_media defines the media that is to be used to back up file systems if space needs to be reallocated during an upgrade because of insufficient space. If multiple tapes or diskettes are required for the backup, you are prompted to insert tapes or diskettes during the upgrade.
Valid type Values
Valid path Values
Specification
local_tape
/dev/rmt/n
A local tape drive on the system that is being upgraded. path must be the character (raw) device path for the tape drive. n is the number of the tape drive.
local_diskette
/dev/rdisketten
A local diskette drive on the system that is being upgraded. path must be the character (raw) device path for the diskette drive. n is the number of the diskette drive.
Diskettes that you use for the backup must be formatted.
local_filesystem
/dev/dsk/cwtxdysz
/file_system
A local file system on the system that is being upgraded. You cannot specify a local file system that is being changed by the upgrade. path can be a block device path for a disk slice. For example, the tx in /dev/dsk/cwtxdysz might not be needed. Or, path can be the absolute path to a file system that is mounted by the /etc/vfstab file.
remote_filesystem
host:/file_system
An NFS file system on a remote system. path must include the name or IP address of the remote system, host, and the absolute path to the NFS file system, file_system. The NFS file system must have read/write access.
remote_systemuser@host:/directory
A directory on a remote system that can be reached by a remote shell, rsh. The system that is being upgraded must have access to the remote system through the remote system's .rhosts file. path must include the name of the remote system host and the absolute path to the directory directory. If a user login ID user is not specified, root is used by default.
Examples:
backup_media local_tape /dev/rmt/0
backup_media local_diskette /dev/rdiskette1
backup_media local_filesystem /dev/dsk/c0t3d0s4
backup_media local_filesystem /export
backup_media remote_filesystem system1:/export/temp
backup_media remote_system user1@system1:/export/temp
boot_device Profile Keyword
boot_device device eeprom
boot_device designates the device where the JumpStart program is to install the root (/) file system and the system's boot device.
If you do not specify the boot_device keyword in a profile, the following boot_device keyword is specified by default during the installation: boot_device any update.
device – Use one of the following values.
eeprom – Choose to update or preserve the system's EEPROM.
SPARC: Choose if you want to update or preserve the system's EEPROM to the specified boot device.
x86: You must specify the preserve value.
Note –
SPARC: On SPARC systems, the eeprom value also allows you to update the system's EEPROM if you change the system's current boot device. By updating the system's EEPROM, the system can automatically boot from the new boot device.
Example:
boot_device c0t0d0s2 update
Note –
boot_device must match any filesys keywords that specify the root (/) file system and the root_device keyword, if specified.
client_arch Profile Keyword
client_arch karch_value ...
client_arch specifies that the operating system server is to support a different platform group than the server uses. If you do not specify client_arch in the profile, any diskless client that uses the operating system server must contain the same platform group as the server. You must specify each platform group that you want the operating system server to support.
Valid values for karch_value are sun4m, sun4u, and i86pc. For a detailed list of platform names and various systems, see Solaris 9 Sun Hardware Guide.
Note –
You can use client_arch only when system_type is specified as server.
client_root Profile Keyword
client_root root_size
client_root defines the amount of root space, root_size in Mbytes, to allocate for each client. If you do not specify client_root in a server's profile, the installation software allocates 15 Mbytes of root space per client. The size of the client root area is used in combination with the num_clients keyword to determine how much space to reserve for the /export/root file system.
Note –
You can use client_root only when system_type is specified as server.
client_swap Profile Keyword
client_swap swap_size
client_swap defines the amount of swap space, swap_size in Mbytes, to allocate for each diskless client. If you do not specify client_swap in the profile, 32 Mbytes of swap space is allocated by default.
Example:
client_swap 64
The example specifies that each diskless client is to have a swap space of 64 Mbytes.
Note –
You can use client_swap only when system_type is specified as server.
How the Size of swap Is Determined
If a profile does not specify the size of swap, the JumpStart program determines the size of the swap space, based on the system's physical memory. Table 28–5 shows how the size of swap is determined during a custom JumpStart installation.
Table 28–5 Determining swap Size
Physical Memory (in Mbytes)
Swap Space (in Mbytes)
16–64
32
64–128
64
128–512
128
Greater than 512
256
The JumpStart program makes the size of swap no more than 20 percent of the disk where swap is located, unless the disk contains free space after laying out the other file systems. If free space exists, the JumpStart program allocates the free space to swap, and if possible, allocates the amount that is shown in Table 28–5.
Note –
Physical memory plus swap space must total a minimum of 32 Mbytes.
cluster Profile Keyword (Adding Software Groups)
cluster group_name
cluster designates the software group to add to the system. The group_name for each software group is listed in the following table.
Software Group
group_name
Core System Support Software Group
SUNWCreq
End User Solaris Software Group
SUNWCuser
Developer Solaris Software Group
SUNWCprog
Entire Solaris Software Group
SUNWCall
Entire Solaris Software Group Plus OEM Support
SUNWCXall
You can specify only one software group in a profile. The software group must be specified before other cluster and package entries. If you do not specify a software group with cluster in the profile, the end–user software group, SUNWCuser, is installed on the system.
cluster Profile Keyword (Adding or Deleting Clusters)
cluster cluster_name add_delete_switch
Note –
cluster (adding or deleting clusters) can be used with both the initial installation and upgrade options.
cluster designates whether a cluster is to be added or deleted from the software group that is to be installed on the system.
cluster_name must be in the form SUNWCname. To view detailed information about clusters and their names, start Admintool on an installed system and choose Software from the Browse menu.
add_delete_switch represents the option add or delete. Use add_delete_switch to indicate whether to add or delete the cluster that is specified. If you do not specify add_delete_switch, add is used by default.
When you use cluster (adding or deleting clusters) during an upgrade, the following conditions apply:
dontuse Profile Keyword
dontuse disk_name ...
By default, the JumpStart program uses all of the operational disks on the system when partitioning default is specified. dontuse designates one or more disks that you do not want the JumpStart program to use. disk_name must be specified in the form cxtydzor cydz, for example, c0t0d0.
Note –
You cannot specify the dontuse keyword and the usedisk keyword in the same profile.
x86: fdisk Profile Keyword
fdisk disk_name type size
fdisk defines how the fdisk partitions are set up on an x86 based system. You can specify fdisk more than once. When fdisk partitions an x86 based system, the following occurs:
disk_name – Use the following values to specify where the fdisk partition is to be created or deleted:
type – Use the following values to specify the type of fdisk partition that is to be created or deleted on the specified disk:
The following table shows the integer and hexadecimal numbers for some of the fdisk types.
fdisk Type
DDD
HH
DOSOS12
1
01
PCIXOS
2
02
DOSOS16
4
04
EXTDOS
5
05
DOSHUGE
6
06
DOSDATA
86
56
OTHEROS
98
62
UNIXOS
99
63
size – Use one of the following values:
filesys Profile Keyword (Mounting Remote File Systems)
filesys server:path server_address mount_pt_name [[mount_options]]
By using filesys with the listed values, the JumpStart program sets up the installed system to automatically mount remote file systems when the system boots. You can specify filesys more than once.
Example:
filesys sherlock:/export/home/user2 - /home
server: – The name of the server where the remote file system is located, followed by a colon.
path – The remote file system's mount–point name. For example, /usr or /export/home.
server_address – The IP address of the server that is specified in server:path. If a name service is not running on the network, the server_address value can be used to populate the /etc/hosts file with the server's host name and IP address. If you are not specifying the server's IP address, you must specify a minus sign (-). For example, if you have a name service that is running on the network, you do not need to specify the server's IP address.
mount_pt_name – The name of the mount point on which the remote file system is to be mounted.
mount_options – One or more mount options, which is the same as the -o option of the mount(1M) command. The mount options are added to the /etc/vfstab entry for the specified mount_pt_name.
Note –
If you need to specify more than one mount option, the mount options must be separated by commas and no spaces (ro,quotafor example).
filesys Profile Keyword (Creating Local File Systems)
filesys slice size [[file_system optional_parameters]]
By using filesys with the values that are listed, the JumpStart program creates local file systems during the installation. You can specify filesys more than once.
slice – Use one of the following values:
file_system – The file_system value is optional and used when slice is specified as any or cwtxdysz. If file_system is not specified, unnamed is set by default. If unnamed is set, you cannot specify the optional_parameters value. Use one of the following values:
optional_parameters – Use one of the following values:
forced_deployment Profile Keyword (Installing Solaris Flash Differential Archives)
forced_deployment
forced_deployment forces the installation of a Solaris Flash differential archive onto a clone system that is different than the software expects.
Caution – Caution –
If you use forced_deployment, all new files are deleted to bring the clone system to the expected state. If you are not certain that you want files deleted, use the default which protects new files by stopping the installation.
geo Profile Keyword
geo locale
Note –
You can use geo with both the initial installation and upgrade options.
geo designates the regional locale or locales that you want to install on a system or to add when upgrading a system. Values you can specify for locale are listed in the following table.
Value
Description
N_Africa
Northern Africa, including Egypt
C_America
Central America, including Costa Rica, El Salvador, Guatemala, Mexico, Nicaragua, Panama
N_America
North America, including Canada, United States
S_America
South America, including Argentina, Bolivia, Brazil, Chile, Colombia, Ecuador, Paraguay, Peru, Uruguay, Venezuela
Asia
Asia, including Japan, Republic of Korea, People's Republic of China, Taiwan, Thailand
Ausi
Australasia, including Australia, New Zealand
C_Europe
Central Europe, including Austria, Czech Republic, Germany, Hungary, Poland, Slovakia, Switzerland
E_Europe
Eastern Europe, including Albania, Bosnia, Bulgaria, Croatia, Estonia, Latvia, Lithuania, Macedonia, Romania, Russia, Serbia, Slovenia, Turkey
N_Europe
Northern Europe, including Denmark, Finland, Iceland, Norway, Sweden
S_Europe
Southern Europe, including Greece, Italy, Portugal, Spain
W_Europe
Western Europe, including Belgium, France, Great Britain, Ireland, Netherlands
M_East
Middle East, including Israel
A complete list of the component locale values that compose each regional locale that is listed previously is presented in Chapter 40, Locale Values (Reference).
Note –
You can specify a geo keyword for each locale you need to add to a system.
install_type Profile Keyword
install_type initial_upgrade_flash_switch
install_type defines whether to erase and install a new Solaris operating environment on a system, upgrade the existing Solaris environment on a system, or install a Solaris Flash archive on the system.
Note –
You must specify install_type in a profile, and install_type must be the first profile keyword in every profile.
You must use one of the following options for the initial_upgrade_flash_switch:
Note –
Some profile keywords can only be used with the initial_install option. Some profile keywords can only be used with the upgrade option. Some profile keywords can only be used with the flash_install option.
isa_bits Profile Keyword
isa_bits bit_switch
isa_bits specifies whether 64-bit or 32-bit Solaris 9 packages are to be installed.
bit_switch represents the option 64 or 32, which you use to indicate whether 64-bit or 32-bit Solaris 9 packages are to be installed. If you do not set this keyword in the profile, the JumpStart program installs systems as follows:
Note –
If you use the isa_bits keyword, you must also use the latest check script in the solaris_9/Misc/jumpstart_sample directory on the Solaris 9 Software 1 of 2 CD or on the Solaris 9 DVD.
layout_constraint Profile Keyword
layout_constraint slice constraint [[minimum_size]]
Note –
You can use layout_constraint only for the upgrade option when you need to reallocate disk space.
layout_constraint designates the constraint auto-layout has on a file system if auto-layout needs to reallocate space during an upgrade because of space problems.
If you do not specify the layout_constraint keyword, the JumpStart program lays out the disk as follows:
If you specify one or more layout_constraint keywords, the JumpStart program lays out the disk as follows:
You cannot change the constraint on file systems that require more space for the upgrade because the file systems must be marked changeable. You can use the layout_constraint keyword to change the minimum_size values on file systems that require more space for the upgrade.
Note –
To help auto-layout reallocate space, select more file systems to be changeable or movable, especially those file systems that are located on the same disks as the file systems that require more space for the upgrade.
slice – slice specifies the file system's disk slice on which to specify the constraint. You must specify the system's disk slice in the form cwtxdyszor cxdysz.
constraint – Use one of the following constraints for the specified file system:
minimum_size – Specifies the size of the file system after auto-layout reallocates space. The minimum_size option enables you to change the size of a file system. The size of the file system might be larger if unallocated space is added to the file system. But, the size is never less than the value you specify. The minimum_size value is optional. Use this value only if you have marked a file system as changeable and the minimum size cannot be less than what the file system needs for the existing file system contents.
Examples:
layout_constraint c0t3d0s1 changeable 200
layout_constraint c0t3d0s4 movable
layout_constraint c0t3d1s3 available
layout_constraint c0t2d0s1 collapse
local_customization Profile Keyword (Installing Solaris Flash Archives)
local_customization local directory
Before you install a Solaris Flash archive on a clone system, you can create custom scripts to preserve local configurations on the clone system. The local_customization keyword designates the directory where you have stored these scripts. local directory is the path to the script on the clone system. For information on predeployment and postdeployment scripts, see Creating Customization Scripts.
locale Profile Keyword
locale locale_name
Note –
You can use locale with both the initial installation and upgrade options.
locale designates the locale packages you want to install or add when upgrading for the specified locale_name. The locale_name values are the same as those values that are used for the $LANG environment variable. Chapter 40, Locale Values (Reference) contains a list of valid locale values.
When you use the local keyword, consider the following:
no_content_check Profile Keyword (Installing Solaris Flash Archives)
no_content_check
When installing a clone system with a Solaris Flash differential archive, you can use the no_content_check keyword to ignore file-by-file validation. File-by-file validation ensures that the clone system is a duplicate of the master system. Avoid using his keyword unless you are sure the clone system is a duplicate of the original master system.
Caution – Caution –
If you use no_content_check, all new files are deleted to bring the clone system to the expected state. If you are not certain that you want files deleted, use the default which protects new files by stopping the installation.
no_master_check Profile Keyword (Installing Solaris Flash Archives)
no_content_check
When installing a clone system with a Solaris Flash differential archive, you can use the no_master_check keyword to ignore checking the clone system to make sure it was built from the original master system. Avoid using this keyword unless you are sure the clone system is a duplicate of the original master system. For information on installing Solaris Flash differential archives, see To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation.
num_clients Profile Keyword
num_clients client_num
When a server is installed, space is allocated for each diskless client's root (/) and swap file systems. num_clients defines the number of diskless clients, client_num, that a server supports. If you do not specify num_clients in the profile, five diskless clients are allocated by default.
Note –
You can use num_clients only when system_type is specified as server.
package Profile Keyword
package package_name [[add_delete_switch]]
Note –
You can use package with both the initial installation and upgrade options.
package designates whether a package is to be added to or deleted from the software group that is to be installed on the system.
You must specify package_name in the form SUNWname. To view detailed information about packages and their names, on an installed system, use the pkginfo -l command.
add_delete_switch represents the option add or delete, which you use to indicate whether to add or delete the specified package. If you do not specify add_delete_switch, add is used by default.
Note –
Some packages are required and cannot be deleted. You cannot individually add or delete localization packages by using the package profile keyword. To add localization packages, use the locale profile keyword.
When you use package for an upgrade, the JumpStart program performs the following actions:
partitioning Profile Keyword
partitioning type
partitioning defines how the disks are divided into slices for file systems during the installation.
type – Use one of the following values:
If you do not specify partitioning in the profile, the default type of partitioning is used by default.
root_device Profile Keyword
root_device slice
Note –
You can use root_device with both the initial installation and upgrade options.
root_device designates the system's root disk. How the System's Root Disk Is Determined contains additional information.
When you are upgrading a system, root_device designates the root (/) file system and the file systems that are mounted by its /etc/vfstab file to be upgraded. You must specify root_device if more than one root (/) file system can be upgraded on a system. You must specify slice in the form cwtxdysz or cxdysz.
Example:
root_device c0t0d0s2
When you use the root_device keyword, consider the following:
A system's root disk is the disk on the system that contains the root (/) file system. In a profile, you can use the rootdisk variable in place of a disk name, which the JumpStart program sets to the system's root disk. Table 28–6 describes how the JumpStart program determines the system's root disk for the installation.
Note –
The JumpStart program only determines a system's root disk size during an initial installation. You cannot change a system's root disk during an upgrade.
Table 28–6 How JumpStart Determines a System's Root Disk (Initial Installation)
Stage
Action
1
If the root_device keyword is specified in the profile, the JumpStart program sets rootdisk to the root device.
2
If rootdisk is not set and the boot_device keyword is specified in the profile, the JumpStart program sets rootdisk to the boot device.
3
If rootdisk is not set and a filesys cwtxdysz size / entry is specified in the profile, the JumpStart program sets rootdisk to the disk that is specified in the entry.
4
If rootdisk is not set and a rootdisk.sn entry is specified in the profile, the JumpStart program searches the system's disks in kernel probe order for an existing root file system on the specified slice. If a disk is found, the JumpStart program sets rootdisk to the found disk.
5
If rootdisk is not set and partitioning existing is specified in the profile, the JumpStart program searches the system's disks in kernel probe order for an existing root file system. If a root file system is not found or more than one is found, an error occurs. If a root file system is found, the JumpStart program sets rootdisk to the found disk.
6
If rootdisk is not set, the JumpStart program sets rootdisk to the disk where the root (/) file system is installed.
system_type Profile Keyword
system_type type_switch
system_type defines the type of system on which the Solaris environment is to be installed.
type_switch represents the option standalone or server, which you use to indicate the type of system on which the Solaris software is to be installed. If you do not specify system_type in a profile, standalone is used by default.
usedisk Profile Keyword
usedisk disk_name ...
By default, the JumpStart program uses all of the operational disks on the system when you specify partitioning default. The usedisk profile keyword designates one or more disks that you want the JumpStart program to use. You must specify disk_name in the form cxtydz or cydz, for example, c0t0d0 or c0d0s0.
If you specify usedisk in a profile, the JumpStart program uses only the disks that you specify after the usedisk keyword.
Note –
You cannot specify the usedisk keyword and the dontuse keyword in the same profile.
