Solaris 9 4/03 Release Notes
x86: Solaris 9 4/03 Installation CD Partition Issue
If the Solaris Web Start 3.0 program on the Solaris 9 4/03 Installation CD is unable to locate a Solaris fdisk partition on a system, you must create a Solaris fdisk partition on your root disk.
Caution – Caution –
If you change the size of an existing fdisk partition, all data on that partition is automatically deleted. Back up your data before you create a Solaris fdisk partition.
The Solaris Web Start 3.0 program requires two fdisk partitions to perform an installation.
Note –
The installation program on the Solaris 9 4/03 Installation CD creates the x86 boot partition, removing 10 Mbytes from the Solaris fdisk partition. This removal prevents any existing fdisk partitions from being altered.
This partition should not be created manually.
This requirement also prevents you from using the Solaris 9 4/03 Installation CD to upgrade from the Solaris 2.6 or Solaris 7 releases to the Solaris 9 4/03 operating environment. For more information, refer to Upgrade Issues.
