Solaris 9 4/03 Release Notes
x86: Service Partition Not Created by Default on Systems With No Existing Service Partition
If you install the Solaris 9 4/03 operating environment on a system that does not currently include a Service partition, the installation program might not create a Service partition by default. If you are including a Service partition on the same disk as the Solaris partition, you must re-create the Service partition before you install the operating environment.
If you installed the Solaris 8 2/02 operating environment on a Sun LX50 system, the installation program might not have preserved the Service partition. If you did not manually edit the fdisk boot-partition layout to preserve the Service partition, the installation program deleted the Service partition during the installation.
Note –
If you did not specifically preserve the Service partition when you installed the Solaris 8 2/02 operating environment, you cannot re-create the Service partition and upgrade to the Solaris 9 4/03 operating environment. You must perform an initial installation of the software.
Workaround: If you are including a Service partition on the disk that contains the Solaris partition, choose one of the following workarounds.
