If you use the suninstall installation program to install the Solaris 9 4/03 (x86 Platform Edition) operating environment on a system with an existing service partition, the installation program might exit. This problem occurs under the following conditions:
You use the suninstall program to install the Solaris 9 4/03 operating environment.
During the installation, you choose to lay out a disk with an existing service partition, but no Solaris fdisk partition.
On the Create Solaris fdisk Partition panel, you choose the Save service partition, create Solaris fdisk partition option.
Workaround: Choose one of the following workarounds.
To manually create a Solaris fdisk partition during the suninstall program, follow these steps:
When the suninstall installation program asks you to choose a method to create the Solaris fdisk partition, choose the Manually create fdisk partitions option.
Preserve the service partition and create the Solaris fdisk partition.
Complete the installation.
To manually create a Solaris fdisk partition by using the fdisk command, follow these steps:
Exit from the suninstall installation program by pressing the F5 function key.
Open a terminal window.
See the fdisk(1M) man page for more information on creating fdisk partitions.
Restart the suninstall installation program by typing the following command:
# suninstall |
