If you use Solaris Management Console to perform operations on a User or Group account on a system that serves as a DNS server, and the /etc/named.conf file exists on that system, errors occur.
The following errors occur when you perform these operations from the GUI or when you use smuser and smgroup, which are command-line interfaces for the console.
The console launches a new dialog box or the smuser command exits with the following error messages when operated on a User:
"The attempt to view Users or Roles has failed due to an unexpected
error.
This was caused by the following error: CIM_ERR_FAILED."
The console launches a new dialog box or the smgroup command exits with the following error message when operated on a Group:
"Attempted Read of Group IDs failed with unexpected CIM error:
CIM_ERR_FAILED."operations from the GUI or command-line interface.
Workaround: Choose from one of the following workarounds.
To solve this problem by restarting the DNS server, follow these steps:
Become superuser.
Move the named.conf file to a different directory. For example:
# mv /etc/named.conf /var/named/named.conf |
Restart the DNS server.
# pkill -9 in.named |
# /usr/sbin/in.named /var/named/named.conf |
To solve this problem by restarting the WBEM server, follow these steps:
Become superuser.
Using a text editor, edit the /usr/sadm/lib/wbem/WbemUtilityServices.properties file.
Replace the /etc/named.conf string with /tmp/new-filename.
Ensure that the file name that you choose does not already exist on the system.
Stop WBEM server.
# /etc/init.d/init.wbem stop |
Start the WBEM server
# /etc/init.d/init.wbem start |
For more information, see the smuser(1M) and the smgroup(1M) man pages.
