If you try to perform various tasks with Veritas Volume Manager on a system that is running the Solaris 9 4/03 operating environment, the vxddladm addjob or vxddladm addsupport utilities might produce a core dump.
Workaround: Follow these steps.
Become superuser.
Verify that the /var/ld/ld.config file and /usr/bin/crle utility exist on the system.
Type the following commands in a terminal window.
# /usr/bin/cp /var/ld/ld.config /var/ld/ld.config.save # /usr/bin/crle -E LD_LIBRARY_PATH=/usr/lib # appropriate-vxddladm-command # /usr/bin/mv /var/ld/ld.config.save /var/ld/ld.config |
