Required Options
-n archive_name
The value of this flag is the name of the archive. The archive_name you specify is the value of the content_name
keyword.
Option for Compression
-c
Compresses the archive
by using compress(1).
Options for Directories and Sizes
-R root
Creates the archive from the file system tree
that is rooted at root. If you do not specify
this option, flar create creates an archive from a file
system that is rooted at /.
-S
Omits sizing information
in the archive.
-H
Does not generate the
hash identifier.
Options for Creating a Differential Archive
-A unchanged_master_image_dir
Create a differential archive by comparing a new
system image with the image that is specified by the unchanged_master_image_dir argument. By default, the new system image is root (/). You can change the default with the -R option. unchanged_master_image_dir is a directory where the unchanged
master system image is stored or mounted through UFS, NFS, or lumount.
You can modify the effects of file selection for a
differential archive by using the options for contents selection described
in the next section of the table.
-M
Excludes the manifest
file. When you use this option, no validation occurs on the differential archive.
When creating a differential archive, flar create creates
a long list of the files in the system that are unchanged, are changed, and
are to be deleted from the archive. This list is stored in the manifest section
of the archive. When the differential archive is deployed, the software uses
this list to perform a file-by-file check, ensuring the integrity of the clone
system. Use of this option avoids such a check and saves the space that is
used by the manifest section in a differential archive. However, you must
consider the savings in time and disk space against the loss of an integrity
check upon installation. Because no validation occurs, avoid using this option.
Options for Contents Selection
Caution – Use the flar create file-exclusion options with caution.
If you exclude some directories, others that you were unaware of might be
left in the archive, such as system configuration files. The system would
then be inconsistent and the installation would not work. Excluding directories
and files is best used with data that can easily be removed without disrupting
the system, such as large data files.
-y include_dir/filename
Adds to the archive those files and directories
that are specified on the command line. This option is used when you've excluded
a directory, but want to restore individual subdirectories or files.
include_dir/filename is the name of the subdirectory or file
to be included.
-f list_filename
Adds files and directories from a list to the archive.
list_filename is the full path to a file that contains a list.
The contents of the file are added to the file list unless -F
is specified.
The list_filename file must contain
one file per line.
If you specify a file system with -R root, the path to each file must be relative to the alternate root directory or an absolute path.
If filename is “-”, flar create reads standard input as the list of files. When you
use the value “-”, the archive size is not calculated.
-F
Uses
only the files in -f list_filename
to create the archive. This option makes the -f list_filename the absolute list, rather than a list that is
appended to the normal file list.
-x exclude_dir/filename
Excludes files and directories from the archive.
These files and directories are specified at the command line. You can use
multiple instances of this option to exclude more than one file or directory.
exclude_dir/filename is the name of
the directory or file to be excluded.
-X list_filename
Excludes a list of files or directories from the archive.
a file that contains the list.
one file per line.
If list_filename is “-”, flar create reads standard input as the list of files. When you
-z list_filename
Excludes or includes a list of files or directories
from the archive. Each file or directory in the list is noted with a plus “+”
or minus “-”. A plus indicates an included file or directory and
the minus indicates an excluded file or directory.
list_filename is the full path to a file that contains the list.
one file per line.
-I
Override the integrity
check. To prevent you from excluding important system files from an archive, flar create runs an integrity check. This check examines all files
that are registered in a system package database and stops archive creation
if any of them are excluded. Use of this option overrides this integrity check.
Therefore, avoid the use of the -I option.
Options Used With User-Defined Sections
-u section
Includes section as a user-defined section. To
include more than one user-defined section, section
must be a space-separated list of section names.
-d dir
Retrieves the section file that is specified with -u from dir.
Options Used With Tape Archives
-t
Creates
an archive on a tape device. The filename argument
is the name of the tape device.
-p posn
Use only with the -t option. Specifies the position on the
tape device for flar create to store the archive. If you
do not use this option, flar create places the archive
at the current position of the tape.
-b blocksize
Specifies the block size flar create uses
when creating the archive. If you do not specify a block size, flar create uses the default block size of 64k.
Options for Archive Identification
These keywords and values
appear in the identification section of the archive.
-U key=val
Includes user-defined keywords and values in the Archive Identification section.
-i date
Uses date as the value for the creation_date keyword. If you do not specify a date, flar create
uses the current system time and date.
-m master
Uses master as the name of the master system on
which you created the archive. master is the value
for the creation_master keyword. If you do not specify master, flar create uses the system name
that is reported by uname -n.
-e descr
Uses descr for the value of the content_description keyword. You cannot use this option when you use the -E option.
-E descr_file
Retrieves the value for the content_description keyword from the descr_file file.
You cannot use this option when you use the -e option.
-a author
Uses author as the author name in the Archive Identification section. author is the value for the content_author
keyword. If you do not specify an author, flar create
does not include the content_author keyword in the Archive
-T type
Uses type as the value for the content_type keyword. type is user defined. If you
do not specify a type, flar create does not include the content_type keyword.
