After you install the master system, the next task in the Solaris Flash installation process is to create a Solaris Flash archive. Files on the master system are copied to a Solaris Flash archive along with various pieces of identification information. You can create a Solaris Flash archive while the master system is running in multiuser mode or single-user mode. You can also create a Solaris Flash archive after you boot from one of the following:
Solaris 9 DVD
Solaris 9 Software 1 of 2 CD
An image of the Solaris 9 Software and the Solaris 9 Languages CDs
