forced_deployment |
forced_deployment forces the installation of a Solaris Flash differential archive onto a clone system that is different than the software expects.
If you use forced_deployment, all new files are deleted to bring the clone system to the expected state. If you are not certain that you want files deleted, use the default which protects new files by stopping the installation.
