Solaris 9 Installation Guide
Guidelines for Selecting a Slice for the root (/) File System
When you create an inactive boot environment, you need to identify a slice where the root (/) file system is to be copied. Use the following guidelines when you select a slice for the root (/) file system. The slice must comply with the following:
