Solaris 9 Installation Guide
Guidelines for Selecting a Slice for a Swap File System
Configuring Swap for the New Boot Environment
You can configure a swap slice in three ways using the lucreate command with the -m option:
The following examples show the three ways of configuring swap. The current boot environment is configured with the root (/) file system on c0t0d0s0. The swap file system is on c0t0d0s1.
Failed Boot Environment Creation If Swap Is In Use
A boot environment creation fails if the swap slice is being used by any boot environment except for the current boot environment. If the boot environment was created using the -s option, the alternate-source boot environment can be using the swap slice, but not any other boot environment.
