To install or upgrade to the Solaris operating environment, the suggested memory size is 128 Mbytes or greater.
Some optional installation features are enabled only when sufficient memory is present. For example, if you install from a DVD with insufficient memory, you install through the Solaris Web Start installation program's command-line interface, not through the Web Start graphical user interface.
