If you use the default Solaris JumpStartTM profile on the Solaris 9 8/03 media to install multiple locales on a system with a small disk, the installation might fail. This problem might occur under the following conditions:
You use the default Solaris JumpStart profile to install any locale other than the C locale on a system with a 2.1-Gbyte disk.
You use the default Solaris JumpStart profile to install two or more locales on a system with a 4-Gbyte disk.
