Solaris 9 8/03 Release Notes
SPARC: flexanlg Command Might Cause Open Failure Error (4742993)
If you are running the Sun ONE Application Server software in the Solaris 9 8/03 operating environment, and you use the flexanlg command from /usr/appserver/bin, the following open failure error is displayed:
ld.so.1: /usr/appserver/bin/flexanlg: fatal: libplc4.so:open failed:
No such file or directory
killed
Workaround: Complete these steps.
  1. Add the following entry to the LD_LIBRARY_PATH file:
    /usr/lib/mps
  2. Run the flexanlg command.
    % /usr/appserver/bin/flexanlg
