Solaris 9 8/03 Release Notes
SPARC: Access Control List Editing Not Supported on Some Versions of Netscape Navigator (4750616)
Sun ONE Application Server Access Control List (ACL) editing is not supported on some versions of Netscape NavigatorTM. If you attempt to edit ACL entries while using either Netscape Navigator version 6.x or Netscape Navigator version 7.x, you might encounter intermittent problems.
For example:
Workaround: Choose one of the following workarounds:
