If you install a patch that supports multiple package architecture, an error similar to the following benign error message might be displayed in the /var/sadm/install_data/Maintenance_Update_log:
Installing xxxxxx-yy (x of xx) See /var/sadm/patch/xxxxxx-yy log for details grep: can't open pdgabbrev.extension/pkginfo |
For example, if patch 123456-01 contains patch packages SUNWcar and SUNWcar.u, the following error message is displayed.
grep: can't open SUNWcar.u/pkginfo |
Workaround: Ignore the error message. The message does not affect the installation of the patch. The message indicates that the patchadd command does not pass the correct parameter to the remove_PATCH_PROPERTIES function.
For more information, refer to the patchadd(1M) man page.
