6to4relay, without arguments, shows the current status of 6to4 relay router support. The first example shows the default.
# /usr/sbin/6to4relay 6to4relay:6to4 Relay Router communication support is disabled |
If relay router support is enabled, 6to4relay displays the following output.
# /usr/sbin/6to4relay 6to4relay:6to4 Relay Router communication support is enabled IPv4 destination address of Relay Router=192.88.99.1 |
If you specified the -a option and IPv4 address to 6to4relay, the IPv4 address that you gave with -a is displayed instead of 192.88.99.1.
6to4relay does not report successful execution of the –d, –e, and -a IPv4 address options. However, 6to4relay does display any errors that might have occurred when you ran these options.
