Before you configure 6to4 routing on an IPv6 network, you must have done the following:
Configured IPv6 on all appropriate nodes at the prospective 6to4 site, as described in How to Enable IPv6 on a Node.
Selected at least one router with a connection to an IPv4 network to become the 6to4 router.
Configured a globally unique IPv4 address for the prospective 6to4 router's interface to the IPv4 network. The IPv4 address must be static. Do not use a dynamically allocated IPv4 address. For instructions for configuring an IPv4 interface, see “Network Configuration Procedures” in System Administration Guide: IP Services
Become superuser on the prospective 6to4 router.
Configure a 6to4 pseudo-interface on the router by creating the /etc/hostname6.ip.6to4tun0 file.
If you plan to use the recommended convention of subnet ID=0 and host ID=1, use the short format for /etc/hostname6.ip.6to4tun0:
tsrc IPv4 address up |
If you plan to use other conventions for subnet ID and host ID, use the long format for /etc/hostname6.ip.6to4tun0:
tsrc IPv4 address 2002:IPv4 address:subnet ID:host ID:/64 up |
The next table explains the parameters of /etc/hostname6.ip.6to4tun0 that are used in this step.
tsrc |
Indicates that this interface is used as a tunnel source |
IPv4 address |
Specifies, in dotted decimal format, the IPv4 address that is configured on the physical interface to become the 6to4 pseudo-interface |
2002 |
(Optional) Specifies the 6to4 prefix |
IPv4 address |
(Optional) Specifies, in hexadecimal, the IPv4 address of the pseudo-interface. |
subnet ID |
(Optional) Specifies, in hexadecimal notation, a subnet ID other than 0 |
host ID |
(Optional) Specifies a host ID other than 1 |
/64 |
Indicates that the address has a length of 64 bits. |
up |
Directs ifconfig to configure the interface as “up” |
Two IPv6 tunnels cannot have the same source and same destination addresses. Packets are dropped as a result. This type of event can happen if a 6to4 router also performs tunneling through atun.
(Optional) Create additional 6to4 pseudo-interfaces on the router.
Each prospective 6to4 pseudo-interface must have an already-configured, globally unique IPv4 address.
Run ifconfig to verify the status of the interface.
# ifconfig ip.6to4tun0 inet6
If the interface is correctly configured, you receive output that is similar to the following.
ip.6to4tun0: flags=2200041<UP,RUNNING,NONUD,IPv6>mtu 1480 index 11
inet tunnel src 129.146.87.188
tunnel hop limit 60
inet6 2002:8192:56bb:56bb::1/64
Edit /etc/inet/ndpd.conf to advertise 6to4 routing.
For detailed information, refer to ndpd.conf(4).
Specify the subnet to receive the advertisement in the first line.
Create an if entry with the following format:
if subnet-interface AdvSendAdvertisements 1 |
For example, to advertise 6to4 routing to the subnet that is connected to interface hme0, replace subnet-interface with hme0.
if hme0 AdvSendAdvertisements 1 |
Add the 6to4 prefix as the second line of the advertisement.
Create a prefix entry with following format:
prefix 2002:IPv4-address:subnet ID::/64 subnet-interface |
prefix 2002 |
Indicates a 6to4 prefix |
IPv4-address |
Specifies, in hexadecimal representation, the unique IPv4 address of the 6to4 pseudo-interface |
subnet ID |
Specifies, in hexadecimal, a subnet ID |
subnet-interface |
Router interface to which the subnet is connected |
Reboot the router.
Alternatively, you can issue a sighup to /etc/inet/in.ndpd to begin sending router advertisements.. The IPv6 nodes on each subnet to receive the 6to4 prefix now autoconfigure with new 6to4–derived addresses.
Add the new 6to4–derived addresses of the nodes to the name service that is used at the 6to4 site.
For instructions, go to How to Add IPv6 Addresses to DNS or How to Add IPv6 Addresses to NIS and NIS+.
For a multiple router site, the routers behind the 6to4 router might require further configuration to support 6to4. If your site uses RIP, you must configure on each non-6to4 router static routes to the 6to4 router. If you use a commercial routing protocol, you do not need to create static routes to the 6to4 router.
The following is an example of the short form of /etc/hostname6.ip.6to4tun0.
# cat /etc/hostname6.ip.6to4tun0 tsrc 129.146.87.188 up |
Here is an example of the long form of /etc/hostname6.ip.6to4tun0.
# cat /etc/hostname6.ip.6to4tun0 tsrc 129.146.87.188 2002:8192:56bb::1/64 up |
The following example shows output of ifconfig for a 6to4 pseudo-interface.
ip.6to4tun0: flags=2200041<UP,RUNNING,NONUD,IPv6> mtu 1480 index 11
tunnel hop limit 60
inet6 2002:8192:56bb::1/64
The next sample /etc/inet/ndpd.conf file advertises 6to4 routing on two subnets.
if qfe0 AdvSendAdvertisements 1 prefix 2002:8192:56bb:1::/64 qfe0 if qfe1 AdvSendAdvertisements 1 prefix 2002:8192:56bb:2::/64 qfe1 |
