IPv6 Administration Guide
Displaying IPv6 Name Service Information
This section provides procedures to display IPv6 name service information.
Displaying IPv6 Name Service Information Task Map
Table 2–4 Displaying IPv6 Name Service Information Task Map
Task
Description
For Information
Display name service information for IPv6
Displays name service information for IPv6 by using the nslookup command.
How to Display IPv6 Name Service Information
Verify that DNS IPv6 PTR records are updated correctly
Displays the PTR records for DNS IPv6 PTR records by using the nslookup command. Also, uses the set q=PTR parameter.
How to Verify That DNS IPv6 PTR Records Are Updated Correctly
Display IPv6 information through NIS
Displays the IPv6 information through NIS by using the ypmatch command.
How to Display IPv6 Information Through NIS
Displays the IPv6 information through NIS+ by using the nismatch command.
How to Display IPv6 Information Through NIS+
Display IPv6 information independent of name service
Displays the IPv6 information by using the getent command.
How to Display IPv6 Information Independent of Name Service
In this procedure, you use the nslookup command to display IPv6 name service information.
  1. On the command line, type the following command:
    % /usr/sbin/nslookup
    The default server name and address appear, followed by the nslookup command angle bracket prompt.
  2. To see information about a particular host, type the following commands at the angle bracket prompt:
    >set q=any
    >host-name
  3. To see only AAAA records, type the following command at the angle bracket prompt:
    >set q=AAAA
  4. Quit the command by typing exit.
Example—Using nslookup to Display IPv6 Information
Default Server:  space1999.Eng.apex.COM
Address:  120.46.168.78
> set q=any
> vallejo
vallejo.ipv6.eng.apex.com      IPv6 address = fec0::9256:a00:fe12:528
vallejo.ipv6.eng.apex.com      IPv6 address = 2::9256:a00:fe12:528
> exit
In this procedure, you use the nslookup command to display PTR records for DNS IPv6.
    The default server name and address display, followed by the nslookup command angle bracket prompt.
  2. To see the PTR records, type the following command at the angle bracket prompt:
    >set q=PTR
  3. Quit the command by typing exit.
Example—Using nslook to Display PTR Records
> set q=PTR
> 8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int
8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int name =
vallejo.ipv6.Eng.apex.COM
ip6.int nameserver = space1999.Eng.apex.COM
> exit
In this procedure, you use the ypmatch command to display IPv6 information through NIS.
    % ypmatch host-name ipnodes.byname
    The information about host-name displays.
Example 2–1 Example—Using ypmatch to Display IPv6 Information Through NIS
% ypmatch vallejo ipnodes.byname
fec0::9256:a00:20ff:fe12:528    vallejo
2::9256:a00:20ff:fe12:528       vallejo
In this procedure, you use the nismatch command to display IPv6 information through NIS.
    % nismatch host-name ipnodes.org-dir
Example 2–2 Example—Using nismatch to Display IPv6 Information Through NIS+
% nismatch vallejo ipnodes.org_dir
vallejo vallejo fec0::9256:a00:20ff:fe12:528
vallejo vallejo 2::9256:a00:20ff:fe12:528
    % getent ipnodes host-name
Example 2–3 Example—Using getent to Display IPv6 Information Independent of Name Service
% getent ipnodes vallejo
2::56:a00:fe87:9aba        vallejo vallejo
fec0::56:a00:fe87:9aba     vallejo vallejo
