The benefits of autoconfiguration are as follows:
Main memory is used more efficiently because modules are loaded when needed.
There is no need to reconfigure the kernel when new devices are added to the system.
Drivers can be loaded and tested without having to rebuild the kernel and reboot the system.
You will use autoconfiguration is used by a system administrator when you add a new device (and driver) to the system. At this time, you will perform a reconfiguration boot so that the system will recognize the new device.
