The following prtconf output is displayed on a SPARC based system.
# prtconf
System Configuration: Sun Microsystems sun4u
Memory size: 128 Megabytes
System Peripherals (Software Nodes):
SUNW,Ultra-5_10
packages (driver not attached)
terminal-emulator (driver not attached)
deblocker (driver not attached)
obp-tftp (driver not attached)
disk-label (driver not attached)
SUNW,builtin-drivers (driver not attached)
sun-keyboard (driver not attached)
ufs-file-system (driver not attached)
chosen (driver not attached)
openprom (driver not attached)
client-services (driver not attached)
options, instance #0
aliases (driver not attached)
memory (driver not attached)
virtual-memory (driver not attached)
pci, instance #0
pci, instance #0
ebus, instance #0
auxio (driver not attached)
power, instance #0
SUNW,pll (driver not attached)
se, instance #0
su, instance #0
su, instance #1
ecpp (driver not attached)
fdthree, instance #0
The following sysdef output is displayed from an x86 based system.
# sysdef * Hostid * 29f10b4d * * i86pc Configuration * * * Devices * +boot (driver not attached) memory (driver not attached) aliases (driver not attached) chosen (driver not attached) i86pc-memory (driver not attached) i86pc-mmu (driver not attached) openprom (driver not attached) options, instance #0 packages (driver not attached) delayed-writes (driver not attached) itu-props (driver not attached) isa, instance #0 motherboard (driver not attached) pnpADP,1542, instance #0 asy, instance #0 asy, instance #1 lp, instance #0 (driver not attached) fdc, instance #0 fd, instance #0 fd, instance #1 (driver not attached) kd (driver not attached) kdmouse (driver not attached) . . . |
