#! /usr/bin/perl -w # # A sample site customization RCM script. # # When RCM_ENV_FORCE is FALSE this script indicates to RCM that it cannot # release the tape drive when the tape drive is being used for backup. # # When RCM_ENV_FORCE is TRUE this script allows DR removing a tape drive # when the tape drive is being used for backup by killing the tape # backup application. # use strict; my ($cmd, %dispatch); $cmd = shift(@ARGV); # dispatch table for RCM commands %dispatch = ( "scriptinfo" => \&do_scriptinfo, "register" => \&do_register, "resourceinfo" => \&do_resourceinfo, "queryremove" => \&do_preremove, "preremove" => \&do_preremove ); if (defined($dispatch{$cmd})) { &{$dispatch{$cmd}}; } else { exit (2); } sub do_scriptinfo { print "rcm_script_version=1\n"; print "rcm_script_func_info=Tape backup appl script for DR\n"; exit (0); } sub do_register { my ($dir, $f, $errmsg); $dir = opendir(RMT, "/dev/rmt"); if (!$dir) { $errmsg = "Unable to open /dev/rmt directory: $!"; print "rcm_failure_reason=$errmsg\n"; exit (1); } while ($f = readdir(RMT)) { # ignore hidden files and multiple names for the same device if (($f !~ /^\./) && ($f =~ /^[0-9]+$/)) { print "rcm_resource_name=/dev/rmt/$f\n"; } } closedir(RMT); exit (0); } sub do_resourceinfo { my ($rsrc, $unit); $rsrc = shift(@ARGV); if ($rsrc =~ /^\/dev\/rmt\/([0-9]+)$/) { $unit = $1; print "rcm_resource_usage_info=Backup Tape Unit Number $unit\n"; exit (0); } else { print "rcm_failure_reason=Unknown tape device!\n"; exit (1); } } sub do_preremove { my ($rsrc); $rsrc = shift(@ARGV); # check if backup application is using this resource #if (the backup application is not running on $rsrc) { # allow the DR to continue # exit (0); #} # # If RCM_ENV_FORCE is FALSE deny the operation. # If RCM_ENV_FORCE is TRUE kill the backup application in order # to allow the DR operation to proceed # if ($ENV{RCM_ENV_FORCE} eq 'TRUE') { if ($cmd eq 'preremove') { # kill the tape backup application } exit (0); } else { # # indicate that the tape drive can not be released # since the device is being used for backup by the # tape backup application # print "rcm_failure_reason=tape backup in progress pid=...\n" ; exit (3); } } |
