The defect menu looks similar to the following:
format> defect
DEFECT MENU:
primary - extract manufacturer's defect list
grown - extract manufacturer's and repaired defects lists
both - extract both primary and grown defects lists
print - display working list
dump - dump working list to file
quit
defect>
The following table describes the defect menu items.
Table 36–5 The defect Menu Item Descriptions|
Sub-Command |
Description |
primary |
Reads the manufacturer's defect list from the disk drive and updates the in-memory defect list. |
grown |
Reads the grown defect list, which are defects that have been detected during analysis, and then updates the in-memory defect list. |
both |
Reads both the manufacturer's defect list and the grown defect list, and then updates the in-memory defect list. |
Displays the in-memory defect list. |
dump |
Saves the in-memory defect list to a file. |
quit |
Exits the defect menu. |
