The labelit command provides new options for use with Universal Disk Format (UDF) file systems. You can use the new labelit command options to identify the author name, organization, and contact information for a UDF volume.
There was no mechanism to update this information, which is part of general UDF file systems, in previous Solaris releases.
The new UDF specific options for the labelit command, specified with the -o option, are the following:
lvinfo1 - Identifies the person who is creating the file system
lvinfo2 - Identifies the organization that is responsible for creating the file system
lvinfo3 - Identifies the contact information for media that contains the UDF file system
The maximum length for each option is 35 bytes.
For more information, see labelit_udfs(1M).
