The following example shows how to check the /dev/rdsk/c0t0d0s6 file system and corrects the incorrect block count.
# fsck /dev/rdsk/c0t0d0s6 checkfilesys: /dev/rdsk/c0t0d0s6 ** Phase 1 - Check Block and Sizes INCORRECT BLOCK COUNT I=2529 (6 should be 2) CORRECT? y ** Phase 2 - Check Pathnames ** Phase 3 - Check Connectivity ** Phase 4 - Check Reference Counts ** Phase 5 - Cylinder Groups 929 files, 8928 used, 2851 free (75 frags, 347 blocks, 0.6% fragmentation) /dev/rdsk/c0t0d0s6 FILE SYSTEM STATE SET TO OKAY ***** FILE SYSTEM WAS MODIFIED ***** |
