System Administration Guide: Basic Administration
Selecting the Best Method for Adding Signed Patches
After you have installed a patch management tool, you can use several different methods of downloading or adding a signed patch or patches to your system. Use the following table to determine which method is best for your needs.
Command or Tool
Description
For More Information
smpatch update
Use this command to identify required patches, and then, automatically download and add the patches to your system.
smpatch(1M)
smpatch analyze
Use this command to identify required patches and display a list of required patch IDs for your system. Then, you could use the smpatch download and smpatch add commands to download and add the patches to your system.
smpatch(1M)
Use these commands to download and add a patch or patches to your system. These commands also download and add any prerequisite patches.
Examples—Downloading and Adding a Signed Patch on a Solaris System (smpatch Command)
ftp and smpatch add
Use the ftp command to transfer a patch or patches to your system. Then, use the smpatch add command to add the patch or patches to your system.
Solaris Management Console Patches Tool
For Solaris 9 systems only – Use this tool when you want the convenience of a GUI tool to manage signed patches.
Solaris Management Console online help
