The following example shows how to determine if the ExampleSoft software component is damaged.
% prodreg browse -m Examplesoft
BROWSE # +/-/. UUID # NAME
1 - root 1 System
Registry
2 + a01ee8dd-1dd1-11b2-a3f2-0800209a5b6b 1 Solaris 9 4/03
System
Software
3 + 8f64eabf-1dd2-11b2-a3f1-0800209a5b6b 1 Unclassified
Software
4 - 95842091-725a-8501-ef29-0472985982be 1 ExampleSoft
233 . 90209809-9785-b89e-c821-0472985982be 1 Example Doc
234 . EXSOzzt 1
235 . EXSOblob 1 Example Data
The ExampleSoft child component EXSOzzt does not have an entry in the NAME column of the Solaris Product Registry. The ExampleSoft software might be damaged. Use the prodreg info command with the -u, -i, and -d options to determine if the ExampleSoft software is damaged.
% prodreg info -u 95842091-725a-8501-ef29-0472985982be -i 1 -d isDamaged=TRUE |
The output of the previous command indicates that the ExampleSoft software is damaged. Use the -a PKGS option to the prodreg info command to identify the ExampleSoft software packages.
% prodreg info
-i 1 -a PKGS
pkgs:
EXSOzzt EXSOblob
Use the pkginfo command to verify that the EXSOzzt and EXSOblob packages are installed on the system.
% pkginfo EXSOzzt ERROR: information for "EXSOzzt" was not found % pkginfo EXSOblob application EXSOblob Example Data |
The output of the pkginfo command indicates that the EXSOzzt package is not installed on the system.
