System Administration Guide: Basic Administration
Fields in the shadow File
The fields in the shadow file are separated by colons and contain the following information:
username:password:lastchg:min:max:warn:inactive:expire
For example:
rimmer:86Kg/MNT/dGu.:8882:0::5:20:8978
The following table describes the shadow file fields.
Table 4–13 Fields in the shadow File
Field Name
Description
username
Contains the user or login name.
password
Might contain the following entries: a 13-character encrypted user password; the string *LK*, which indicates an inaccessible account; or the string NP, which indicates no password for the account.
lastchg
Indicates the number of days between January 1, 1970, and the last password modification date.
min
Contains the minimum number of days required between password changes.
max
Contains the maximum number of days the password is valid before the user is prompted to specify a new password.
inactive
Contains the number of days a user account can be inactive before being locked.
expire
Contains the absolute date when the user account expires. Past this date, the user cannot log in to the system.
