UIDs and GIDs can be assigned up to the maximum value of a signed integer, or 2147483647.
However, UIDs and GIDs over 60000 do not have full functionality and are incompatible with many Solaris features, so avoid using UIDs or GIDs over 60000.
The following table describes interoperability issues with Solaris products and previous Solaris releases.
Table 4–2 Interoperability Issues for UIDs or GIDs Over 60000|
Category |
Product or Command |
Issues or Cautions |
NFSTM Interoperability |
SunOSTM 4.0 NFS software and compatible releases |
NFS server and client code truncates large UIDs and GIDs to 16 bits. This situation can create security problems if systems running SunOS 4.0 and compatible releases are used in an environment where large UIDs and GIDs are being used. Systems running SunOS 4.0 and compatible releases require a patch to avoid this problem. |
Name Service Interoperability |
NIS name service and file-based name service |
Users with UIDs greater than 60000 can log in or use the su command on systems running the Solaris 2.5 and compatible releases, but their UIDs and GIDs will be set to 60001 (nobody). |
NIS+ name service |
Users with UIDs greater than 60000 are denied access on systems running Solaris 2.5 and compatible releases and the NIS+ name service. |
Table 4–3 Large UID or GID Limitation Summary
