The ldap_cachemgr daemon must be running and functioning correctly at all times. Otherwise, the system doesn't work. There are two ways to check if ldap_cachemgr is running.
Use the ps command with the ef option.
# ps -ef | grep ldap_cachemgr |
Pass the -g option to ldap_cachemgr.
This option provided status information, which is useful when you are diagnosing a problem.
# /usr/lib/ldap/ldap_cachemgr -g
cachemgr configuration:
server debug level 0
server log file "/var/ldap/cachemgr.log"
number of calls to ldapcachemgr 19
cachemgr cache data statistics:
Configuration refresh information:
Previous refresh time: 2001/11/16 18:33:28
Next refresh time: 2001/11/16 18:43:28
Server information:
Next refresh time: 2001/11/16 18:36:08
server: 192.168.0.0, status: UP
server: 192.168.0.1, status: ERROR
error message: Can't connect to the LDAP server
Cache data information:
Maximum cache entries: 256
Number of cache entries: 2
