By using the PAM framework, you can choose among several authentication services. You can use either pam_unix(5) or pam_ldap(5) in conjunction with LDAP.
Because of its increased flexibility, support of stronger authentication methods, and ability to use account management, the use of pam_ldap is recommended.
If you have not changed the pam.conf(4) file, pam_unix(5) is enabled by default. pam_unix(5) follows the traditional model of UNIX authentication, which means the following:
The client retrieves the user's encrypted password from the name service.
The user is prompted for his password.
The user's password is encrypted.
The client compares the two encrypted passwords to determine whether the user should be authenticated.
The password must be stored in UNIX crypt format and not in any other encryption methods, including clear.
The userPassword attribute must be readable by the name service.
For example, if you set the credential level to anonymous, then anyone must be able to read the userPassword attribute. Similarly, If you set the credential level to proxy, then the proxy user must be able to read the userPassword attribute.
pam_unix(5) is not compatible with the sasl authentication method digest-MD5, since Sun ONE Directory Server 5.1 requires passwords to be stored in the clear in order to use digest-MD5. pam_unix requires the password be stored in crypt format.
When using pam_ldap(5), the user binds to the LDAP server using the authentication method defined in pam_ldap's serviceAuthenticationMethod parameter, if one exists. Otherwise, authenticationMethod is used by default.
If pam_ldap(5) is able to bind to the server with the user's identity and supplied password, it authenticates the user.
pam_ldap(5) does not read the userPassword attribute. Therefore, there is no need to grant access to read the userPassword attribute unless there are other clients using pam_unix(5). pam_ldap(5) does not support the none authentication method. Thus, you must define the serviceAuthenticationMethod or the authenticationMethod attributes so clients can use pam_ldap(5).
If the simple authentication method is used, the userPassword attribute can be read on the wire by third parties.
See Example pam.conf File for pam_ldap.
The following table summarizes the main differences between pam_unix and pam_ldap.
Table 13–5 pam_unix vs. pam_ldap|
pam_unix |
pam_ldap |
Password Sent |
Uses passwd service authentication method |
New Password Sent |
Encrypted |
No encryption (unless TLS is used) |
New Password Stored |
crypt format |
As defined on Sun ONE DS 5.1 by default passwd storage scheme |
Requires password read? |
Yes |
No |
sasl/digest—MD5 compatibility after changing password |
No. Password is not stored in clear. User cannot authenticate. |
Yes. As long as default storage scheme is set to clear, user can authenticate. |
Use passwd(1) to change a password. In order to change the password, the userPassword attribute must be writeable by the user. Remember that the serviceAuthenticationMethod for passwd-cmd will override the authenticationMethod for this operation. Depending on the authentication used, the current password might be un-encrypted on the wire.
In the case of pam_unix(5), the new userPassword attribute is encrypted using UNIX crypt format and tagged before being written to LDAP. Therefore, the new password is encrypted on the wire, regardless of the authentication method used to bind to the server.
For pam_ldap, when a password is changed, the new password is un-encrypted. Therefore, to insure privacy, use TLS. If TLS is not used, the new userPassword will be subject to snooping.
When setting the password with pam_ldap(5) with Sun ONE Directory Server 5.1, the password is encrypted using the passwordStrorageScheme (as it is untagged). See “User Account Management” in the Sun ONE Directory Server 5.1 Administrator's Guide for additional information about the passwordStorageScheme attribute.
You need to consider the following when setting the passwordStorageScheme attribute. If a NIS, NIS+, or another client using pam_unix is using LDAP as a repository, then passwordStorageScheme needs to be crypt. Also, if using pam_ldap with sasl/digest-MD5 with Sun ONE Directory Server 5.1, passwordStorageScheme must be set to clear. See the following section for more information.
If you are using the Sun ONE Directory Server with digest-MD5, a user who changes her password will not be able to login with the new password if the change fails for any password management reason.
For example, is password history is enabled on the server and the user attempts to change her password to a previously used password, pam_ldap fails to change the password due to the constraint violations (a previously used password in this case). pam ignores pam_ldap and falls through to pam_unix. As a result, the password is stored in crypt format and not in the clear. Consequently, the next time the user attempts to login with her new password, her login will fail.
To avoid having pam_ldap “fall through” to pam_unix, use the following configuration on all clients' pam.conf files:
other password required pam_dhkeys.so.1 other password requisite pam_authtok_get.so.1 other password requisite pam_authtok_check.so.1 other password binding pam_authtok_store.so.1 server_policy |
Note that there is no pam_ldap.so.1 in the above configuration. The server_policy specifies that pam_authtok_store.so.1 should always send clear text for LDAP accounts to the directory server and allows the server to store the password according to its own password encryption scheme. However, when using the above configuration, you also need the matching authentication configurations. For example, use the following configuration:
login auth binding pam_unix_auth.so.1 server_policy login auth required pam_ldap.so.1 |
and
passwd auth binding pam_passwd_auth.so.1 server_policy passwd auth required pam_ldap.so.1 |
Make sure that every client in the same directory naming domain uses the configuration above. If even one client is using a different pam.conf, if a user changes her password on that system, login authentication will fail on the rest of the clients.
