System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
timezone Attributes and Object Class
Create attributes and object class as below, and then create the container for the timezone data. The suggested container name is ou=Timezone. (The LDIF data is suitable for ldapadd(1). Attribute and object class OIDs are examples only.)
dn: cn=schema
changetype: modify
add: attributetypes
attributetypes:	( 1.3.6.1.4.1.42.2.27.5.42.42.15.0 NAME 'nisplusTimeZone' \
		  DESC 'tzone column from NIS+ timezone table' \
		  SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE )
dn: cn=schema
changetype: modify
add: objectclasses
objectclasses:	( 1.3.6.1.4.1.42.2.27.5.42.42.16.0 NAME 'nisplusTimeZoneData' \
		  DESC 'NIS+ timezone table data' \
		  SUP top STRUCTURAL MUST ( cn ) \
		  MAY ( nisplusTimeZone $ description ) )
To create the ou=Timezone container, put the following LDIF data in a file. Substitute your actual search base for searchBase.
dn: ou=Timezone,searchBase ou: Timezone objectClass: top
objectClass: organizationalUnit
Use the above file as input to ldapadd(1) in order to create the ou=Timezone container. For example, if your LDAP administrator DN is cn=directory manager, and the file with the LDIF data is called tzfile.
# ldapadd -D cn="directory manager" -f tzfile
Depending on the authentication required, the ldapadd command might prompt for a password.
The /var/nis/NIS+LDAPmapping.template file contains commented-out definitions for the timezone.org_dir table. Copy these to the actual mapping file, enable by removing the comment character '#', and restart therpc.nisd daemon. If necessary, synchronize NIS+ and LDAP data as described in NIS+ to LDAP Migration Scenarios.
