LDAP command-line tools support a common set of options, including authentication and bind parameters.
These commands can be used to manipulate directory entries directly. The ldapsearch(1), ldapmodify(1), ldapadd(1), and ldapdelete(1) tools support a common text-based format for representing directory information called the LDAP Data Interchange Format (LDIF).
