次の例では、passwd と shadow ファイルが /var/tmp ディレクトリに復元されます。
# cd /var/tmp # ufsrestore xvf /dev/rmt/0 ./etc/passwd ./etc/shadow Verify volume and initialize maps Media block size is 126 Dump date: Wed Dec 12 10:54:45 2001 Dumped from: the epoch Level 0 dump of / on earth:/dev/dsk/c0t1d0s0 Label: none Extract directories from tape Initialize symbol table. Make node ./etc Extract requested files You have not read any volumes yet. Unless you know which volume your file(s) are on you should start with the last volume and work towards the first. Specify next volume #: 1 extract file ./etc/passwd extract file ./etc/shadow Add links Set directory mode, owner, and times. set owner/mode for `.'? [yn] n # cd etc # mv passwd /etc # mv shadow /etc # ls -l /etc |
