To view the framework configuration, which also contains default elements created by the system, type:
# pooladm
system host
string system.comment
int system.version 1
boolean system.bind-default true
int system.poold.pid 177916
string system.poold.objectives wt-load
pool dev_pool
int pool.sys_id 125
boolean pool.default false
boolean pool.active true
int pool.importance 1
string pool.comment
string pool.scheduler IA
pset dev_pset
pool appserver_pool
int pool.sys_id 124
string pool.comment
string pool.scheduler TS
pset app_pset
pool db_pool
int pool.sys_id 123
string pool.comment
string pool.scheduler FSS
pset db_pset
pool tp_pool
int pool.sys_id 122
string pool.comment
pset tp_pset
pool pool_default
int pool.sys_id 0
boolean pool.default true
string pool.comment
pset pset_default
pset dev_pset
int pset.sys_id 4
string pset.units population
boolean pset.default false
uint pset.min 0
uint pset.max 2
string pset.comment
boolean pset.escapable false
uint pset.load 0
uint pset.size 0
string pset.poold.objectives locality tight; utilization < 80
pset tp_pset
int pset.sys_id 3
uint pset.min 2
uint pset.max 8
string pset.comment
uint pset.load 0
uint pset.size 0
string pset.poold.objectives locality tight; 2: utilization < 80
cpu
int cpu.sys_id 1
string cpu.comment
string cpu.status on-line
cpu
int cpu.sys_id 2
string cpu.comment
pset db_pset
int pset.sys_id 2
uint pset.min 4
uint pset.max 6
string pset.comment
uint pset.load 0
uint pset.size 0
cpu
int cpu.sys_id 3
string cpu.comment
cpu
int cpu.sys_id 4
string cpu.comment
cpu
int cpu.sys_id 5
string cpu.comment
cpu
int cpu.sys_id 6
string cpu.comment
pset app_pset
int pset.sys_id 1
uint pset.min 1
uint pset.max 2
string pset.comment
uint pset.load 0
uint pset.size 0
cpu
int cpu.sys_id 7
string cpu.comment
pset pset_default
int pset.sys_id -1
boolean pset.default true
uint pset.min 1
uint pset.max 4294967295
string pset.comment
uint pset.load 0
uint pset.size 0
cpu
int cpu.sys_id 0
string cpu.comment
A graphic representation of the framework follows.
In the pool db_pool, the standalone database instance is guaranteed 75 percent of the CPU resource.
