Task |
Description |
For Instructions |
Use the console |
Start the Solaris Management Console in a local environment or in a name service or directory service environment. Note that the performance tool is not available in a name service environment. |
Starting the Solaris Management Console in System Administration Guide: Basic Administration and Using the Solaris Management Tools in a Name Service Environment (Task Map) in System Administration Guide: Basic Administration |
Monitor system performance |
Access the Performance tool under System Status. | |
Add resource controls to projects |
Access the Resource Controls tab under System Configuration. |
