Each successful login into a project creates a new task that contains the login process. The task is a process collective that represents a set of work over time. A task can also be viewed as a workload component. Each task is automatically assigned a task ID.
Each process is a member of one task, and each task is associated with one project.
All operations on process groups, such as signal delivery, are also supported on tasks. You can also bind a task to a processor set and set a scheduling priority and class for a task, which modifies all current and subsequent processes in the task.
A task is created whenever a project is joined. The following actions, commands, and functions create tasks:
login
cron
newtask
setproject
su
You can create a finalized task by using one of the following methods. All further attempts to create new tasks will fail.
You can use the newtask command with the -F option.
You can set the task.final attribute on a project in the project naming service database. All tasks created in that project by setproject have the TASK_FINAL flag.
For more information, see the login(1), newtask(1), cron(1M), su(1M), and setproject(3PROJECT) man pages.
The extended accounting facility can provide accounting data for processes. The data is aggregated at the task level.
