When file systems are mounted from within a zone, the nodevices option applies. For example, if a zone is granted access to a block device (/dev/dsk/c0t0d0s7) and a raw device (/dev/rdsk/c0t0d0s7) corresponding to a UFS file system, the file system is automatically mounted nodevices when mounted from within a zone. This rule does not apply to mounts specified through a zonecfg configuration.
Options for mounting file systems in non-global zones are described in the following table. Procedures for these mounting alternatives are provided in Configuring, Verifying, and Committing a Zone and Mounting File Systems in Running Non-Global Zones.
Any file system type not listed in the table can be specified in the configuration if it has a mount binary in /usr/lib/fstype/mount.
File System |
Mounting Options in a Non-Global Zone |
AutoFS |
Cannot be mounted using zonecfg, cannot be manually mounted from the global zone into a non-global zone. Can be mounted from within the zone. |
CacheFS |
Cannot be used in a non-global zone. |
FDFS |
Can be mounted using zonecfg, can be manually mounted from the global zone into a non-global zone, can be mounted from within the zone. |
HSFS |
LOFS |
MNTFS |
NFS |
Cannot be mounted using zonecfg. V2, V3, and V4, which are the versions currently supported in zones, can be mounted from within the zone. |
PCFS |
PROCFS |
TMPFS |
UDFS |
UFS |
XMEMFS |
Can be mounted using zonecfg, can be manually mounted from the global zone into a non-global zone, can be mounted from within the zone. Support for this file system is being removed from the Solaris system in a future release. |
ZFS |
Can be mounted using the zonecfg dataset and fs resource types. |
For more information, see How to Configure the Zone, Mounting File Systems in Running Non-Global Zones, and the mount(1M) man page.
