System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
Using the zonecfg Command to Revert or Remove a Zone Configuration
Use the zonecfg command described in zonecfg(1M) to revert a zone's configuration or to delete a zone configuration.
ProcedureHow to Revert a Zone Configuration
While configuring a zone with the zonecfg utility, use the revert subcommand to undo a resource setting made to the zone configuration.
You must be the global administrator in the global zone to perform this procedure.
  1. Become superuser, or assume the Primary Administrator role.
    To create the role and assign the role to a user, see Using the Solaris Management Tools With RBAC (Task Map) in System Administration Guide: Basic Administration.
  2. While configuring a zone called tmp-zone, type info to view your configuration:
    zonecfg:tmp-zone> info
    The net resource segment of the configuration displays as follows:
    fs:
            dir: /tmp
            special: swap
            type: tmpfs
    net:
            address: 192.168.0.1
            physical: eri0
    device
            match: /dev/pts/*
  3. Remove the net address:
    zonecfg:tmp-zone> remove net address=192.168.0.1
  4. Verify that the net entry has been removed.
    fs:
            dir: /tmp
            special: swap
            type: tmpfs
    device
            match: /dev/pts/*
  5. Type revert.
    zonecfg:tmp-zone> revert
  6. Answer yes to the following question:
    Are you sure you want to revert (y/[n])? y
  7. Verify that the net address is once again present:
    fs:
            dir: /tmp
            special: swap
            type: tmpfs
    net:
            physical: eri0
    device
            match: /dev/pts/*
ProcedureHow to Delete a Zone Configuration
Use zonecfg with the delete subcommand to delete a zone configuration from the system.
  2. Delete the zone configuration for the zone a-zone by using one of the following two methods:
    • Use the -F option to force the action:
      global# zonecfg -z a-zone delete -F
    • Delete the zone interactively by answering yes to the system prompt:
      Are you sure you want to delete zone a-zone (y/[n])? y
