The following example shows how to restore the /export/home file system.
# umount /export/home # newfs /dev/rdsk/c0t3d0s7 newfs: construct a new file system /dev/rdsk/c0t3d0s7: (y/n)? y /dev/rdsk/c0t3d0s7: 410400 sectors in 270 cylinders of 19 tracks, 80 sectors 200.4MB in 17 cyl groups (16 c/g, 11.88MB/g, 5696 i/g) super-block backups (for fsck -F ufs -o b=#) at: 32, 24432, 48832, 73232, 97632, 122032, 146432, 170832, 195232, 219632, 244032, 268432, 292832, 317232, 341632, 366032, 390432, # mount /dev/dsk/c0t3d0s7 /mnt # cd /mnt # ufsrestore rvf /dev/rmt/0 Verify volume and initialize maps Media block size is 126 Dump date: Sat Jul 14 08:49:33 2001 Dumped from: the epoch Level 0 dump of /export/home on earth:/dev/dsk/c0t3d0s7 Label: none Begin level 0 restore Initialize symbol table. Extract directories from tape Calculate extraction list. Warning: ./lost+found: File exists Make node ./kryten Make node ./kryten/letters Make node ./kryten/reports Extract new leaves. Check pointing the restore extract file ./kryten/.cshrc extract file ./kryten/.login extract file ./kryten/b extract file ./kryten/memos extract file ./kryten/letters/b extract file ./kryten/letters/letter1 extract file ./kryten/letters/letter2 extract file ./kryten/letters/letter3 extract file ./kryten/reports/reportA extract file ./kryten/reports/reportB extract file ./kryten/reports/reportC Add links Set directory mode, owner, and times. Check the symbol table. Check pointing the restore # ls # rm restoresymtable # cd / # umount /mnt # ufsdump 0ucf /dev/rmt/0 /export/home . . . # mount /dev/dsk/c0t3d0s7 /export/home # ls /export/home |
